Southchip has rolled out the SC8002A, an efficient synchronous step-down controller tailored for multi-port chargers, automotive adapters, docking stations, and industrial power supplies. Supporting a 4.6V to 36V wide input range, the IC adapts easily to single or dual-channel configurations. Featuring built-in constant-current control, programmable peak current limits, and power capping, the SC8002A enables dynamic power sharing under heavy multi-device loads, curbing overload risks while saving valuable board space in dense power architectures.
Engineered for ultimate versatility, the SC8002A supports near 100% duty cycle operation to minimize dropout voltage and maximize efficiency as input levels track output values. In multi-output scenarios, reaching a channel's current threshold prompts a smooth transition into constant-current regulation. Switching frequency is adjustable from 80kHz to 600kHz with selectable PWM/PFM operation, while integrated line-drop compensation guarantees steady voltage delivery over long cords and multi-port arrays. Robust safety suites comprise UVLO, OVP, OCP, thermal shutdown, and hiccup auto-recovery, all packed into a tiny 3mm x 3mm QFN20 footprint.
The SC8002A addresses multi-load distribution challenges in complex charging hubs and accessories by merging wide-input step-down, flexible channel allocation, and smart current-power limiting. It condenses board layout while fortifying high-load reliability with comprehensive safeguards. As the portable and automotive power landscape trends toward multi-interface, high-wattage densities, the SC8002A is well-poised to drive the next wave of compact multi-channel designs.
