Home › News › APsystems Showcases Residential Storage Innovation at Intersolar Europe 2026
At the recently concluded Intersolar Europe 2026 in Munich, APsystems took center stage with its latest APstorage product line, featuring the LSH-6 and LSA-6 inverters. These solutions underline the company's commitment to residential PV+storage integration.
APsystems Showcases Residential Storage Innovation at Intersolar Europe 2026-Chargerlab
As the central hub connecting solar, batteries, and the home grid, the storage inverter is the linchpin of modern energy independence.
The LSH-6 hybrid inverter offers an all-in-one solution for new installations, combining PV conversion, storage, and intelligent energy management. With a 6kVA rated output, 9kVA peak, and 97.6% efficiency, it is designed to support up to 12kW of solar capacity. Meanwhile, the LSA-6 AC-coupled inverter provides an easy path for existing PV owners to add battery storage without complex system overhauls, offering output options from 3.68kW to 6kW and 96.1% peak efficiency.
Both models feature a 48V low-voltage architecture and support 125A charging/discharging, coupled with a seamless 4ms UPS-grade power transition. Designed for the home, both models operate at a whisper-quiet 30dB with a fanless cooling design. Installation is further simplified through tool-less wiring and a compact design that reduces the footprint by 20% compared to traditional models.
By balancing the needs of new builds (LSH-6) and system retrofits (LSA-6), APsystems is effectively addressing the full spectrum of the European residential storage market. This performance at Intersolar Europe 2026 signals a pivotal shift, as APsystems successfully transitions from its microinverter roots into a comprehensive provider of residential, balcony, and distributed energy storage solutions.
1. Revolutionizing Desktop Storage | Hands-on with the 3D-Printed 8-Slot "Push-to-Eject" AA Battery Organizer
2. ACASIS 80Gbps Storage:The Ultimate Powerhouse for AI and Creative Pros
April 20, 2025
Navitas’ GaNFast™ Enables 2x Shrink and 75% More Emergency Lighting
May 16, 2019
Red Dot Design Award Winner! aigo P5 Magnetic Portable SSD
May 26, 2026
Chipown’s PN6869: A Next-Gen Open-Loop LLC Controller for 800V HVDC Data Centers
May 20, 2026
