Home › News › Weltrend’s WT6679F Is Bringing 240W PD3.2 Charging to E-Bikes and Portable Power
Weltrend is pushing the boundaries of high-voltage battery management with its new WT6679F controller. Built for the era of 240W USB-C charging, this chip is designed to streamline power delivery for e-bikes and portable storage units.
Weltrend’s WT6679F Is Bringing 240W PD3.2 Charging to E-Bikes and Portable Power-Chargerlab
By supporting the PD3.2 EPR 48V specification, the WT6679F allows for efficient 48V/5A power transmission, solving the heat and loss issues typically associated with high-amperage cables. Its DRP (Dual Role Power) capability is a highlight—a single USB-C port can now both charge the battery and power external high-drain devices like laptops, effectively reducing hardware clutter.
With its wide 4V–66V operating range and integration of power conversion control, the WT6679F acts as a complete "system-on-a-chip" for battery packs. From comprehensive OVP/OCP/UVP protections to E-Marker identification and liquid detection, it’s a robust solution for developers aiming to integrate safe, high-speed USB-C charging into demanding power applications.
1. iCM Chip Joins Tesla Supply Chain: A Milestone for China’s Semiconductor Industry
2. Southchip SC8723: A High-Integration Solution for Compact Buck-Boost Power
3. SiPower Drops High-Performance Secondary SR Chip SP6521H
Beryl Showcases Wide Range of Capacitors at USB-PD Asia 2019
August 28, 2019
SouthChip’s Six Chips Receive UFCS Certification
April 8, 2025
Injoinic IP2191 Becomes the First CTTL-Certified VOOC Chip
June 14, 2019
AA Meets Coin Cells | Hands-On with a Multifunctional 3D Printed Battery Case
June 22, 2026
