Home › News › SiPower Drops High-Performance Secondary SR Chip SP6521H
SiPower’s latest release, the SP6521H, is a high-performance secondary synchronous rectification (SR) controller chip built right for flyback power supplies. Aimed to replace old-school, low-drop Schottky diode layouts, this chip shaves off serious stage losses, bumps up system efficiency, and cools down the thermal and sizing bottlenecks of modern power gear. Under the hood, SiPower’s own 65W PD fast charging scheme rocks a golden combo—pairing a high-frequency QR flyback master with this exact SP6521H SR controller—proving it has what it takes to dominate the commercial market.
SiPower Drops High-Performance Secondary SR Chip SP6521H-Chargerlab
Out of the box, the SP6521H fully backs CCM, QR, and DCM modes, giving complete coverage for standard flyback power blueprints. Thanks to its smart self-powering layout, it strips down the external component recipe, running down to a 3.3V output while its VS sampling pin handles a massive 120V rating. On the power draw front, it idles at a tiny 310μA quiescent current, keeps light-load loss down to a tight 2%–6%, and cranks up to a blazing 500KHz switching frequency. To kill the risk of accidental cross-conduction and keep system stability locked in, the SP6521H is lightning fast, flashing a 10ns turn-off delay and a heavy-duty 4A pull-down current to supercharge the external SR MOSFET’s turn-off speed.
The SiPower SP6521H wins big by packing killer SR control, wide mode flexibility, high-frequency support, and a self-contained power loop all into a tiny SOT23-5 housing. For heavy-current, high-density gear like fast charging bricks and multi-port USB power adapters, this chip tames hot thermals and optimizes overall efficiency without bloating PCB space or adding external complexity. For power engineers in 2026, it is the ultimate choice to smash down size limits while delivering heavy-duty performance.
1. Fantastichip FAN6631: A High-Efficiency Multi-Mode PFC Controller for Modern Power Solutions
2. Innoscience GaN Chip Empowers EcoFlow 65W Charger to Meet Multi-Device Fast Charging Demands
3. iCM Chip Joins Tesla Supply Chain: A Milestone for China’s Semiconductor Industry
The Energy Label Shakeup Is Here: Global 'Dual Carbon' Push Triggers Power Compliance Reshuffle
Powering Innovation, How Youwang Electronics is Dominating PC Power Control
Teardown of BMW 18W Dual USB Car Charger (1A1C)
July 13, 2022
JADARD's USB PD 3.1 PPS Protocol Controller: JD6610C
March 15, 2025
Galaxy Microelectronics to Acquire 100% Stake in Hunteck for Strategic Entry into High-End Power Semiconductors
June 12, 2026
BLUETTI AC180 Portable Power Station: A Versatile and Reliable Power Solution
May 3, 2023
