Home › News › Breaking the Proprietary Barrier: Greenworks Unveils 100W USB-C Enabled Battery Pack
Breaking the Proprietary Barrier: Greenworks Unveils 100W USB-C Enabled Battery Pack-Chargerlab
Say goodbye to dedicated charging stations. Greenworks has just launched the PA600, a game-changing 24V battery pack that doubles as a high-performance power bank. Designed for the 24V POWERALL ecosystem, this 6Ah battery is compatible with over 200 tools, combining heavy-duty power with the convenience of USB-C PD charging.
The highlight is the built-in USB-C port. Not only can you charge the battery using your laptop or phone charger, but you can also flip the switch to output 100W of power—enough to keep your mobile devices and even laptops running while on the job site or in the great outdoors. It’s a versatile, all-in-one power solution that eliminates the clutter of proprietary chargers.
Safety and durability are at the core of the PA600. With its advanced BMS, quad-protection system, and industry-standard certifications (CE/FCC/UL), users can rest assured that their gear is safe. Wrapped in a rugged, flame-retardant, and shock-resistant casing, it’s built to survive the toughest outdoor environments. Plus, with a simple LED power indicator, you’ll always know how much juice you have left.
Greenworks is leading the charge in unified connectivity. By bringing USB-C to the world of outdoor power tools, they are effectively bridging the gap between professional work gear and daily electronics, offering a smarter, more mobile way to stay powered up.
1. Ditching the Old Standards:Walmart Hyper Tough Battery Pack Gains USB-C Fast Charge Support
2. 10000mAh Power Bank丨 MOMAX Released Upgraded Magnetic Wireless Battery Pack with Stand
3. Teardown of Zhizu 2700Wh Zhiba MAX LiFePO₄ Swappable Battery Pack (DM60N-45ET)
Application Cases of MPS HR1211
February 7, 2025
MPS Unveils HFG610A-45: High-Efficiency GaN Flyback Regulator for Compact Power Solutions
September 26, 2024
Efficient Graphics Processing Performance | Six OCuLink GPU Docks Inventory
October 3, 2024
April 21, 2026
