Home › News › Ditching the Old Standards:Walmart Hyper Tough Battery Pack Gains USB-C Fast Charge Support
Standard power tool batteries are often tied to dedicated chargers, leaving users stranded when tools aren't compatible with common cables. Walmart’s Hyper Tough is changing the game with its 20V 4.0Ah lithium battery pack, featuring USB-C PD bidirectional fast charging. By allowing users to juice up with a simple phone charger while offering massive capacity, it hits the sweet spot of performance and value for DIYers and homeowners alike.
Ditching the Old Standards:Walmart Hyper Tough Battery Pack Gains USB-C Fast Charge Support-Chargerlab
Built on a 20V platform, its 4.0Ah capacity keeps high-drain tools like drills, angle grinders, lawnmowers and blowers running at peak performance for the long haul. With no drop in power throughout the cycle, it sails through heavy DIY projects from yard work to home repairs. Best of all, it’s a 'one-size-fits-all' solution for the entire Hyper Tough 20V lineup, saving users the hassle and cost of buying separate batteries for every tool.
Breaking away from the norm, it features a USB-C and a USB-A port. The USB-C port is marked 'IN/OUT' for bidirectional fast charging, meaning you can juice it up with the same PD brick you use for your phone or tablet. No more hauling around bulky dedicated chargers—it’s built for grab-and-go convenience whether you're at home, off-road, or at the construction site.
Official specs confirm the USB-C port hits 45W for both input and output, paired with a 27W USB-A port. This setup lets you juice up two devices at once, turning the battery into a high-capacity power bank for your phone, tablet, or even an Ultrabook. It’s the ultimate two-in-one solution for keeping both your tools and your tech powered up on the go.
Additionally, it supports even faster charging via a dedicated charger. The built-in LED battery gauge keeps you informed of the power level so you're never caught off guard mid-task. Built with a rugged, drop-proof shell and packed with four-layer safety shielding (guarding against overcharge, over-drain, and spikes), it’s a tank of a battery that’s as safe as it is tough.
The Walmart Hyper Tough 20V 4.0Ah battery pack features a smart USB-C PD design that keeps its USB ports wide open even when the dedicated charger is plugged in. It’s a major leap toward making home tools more universal and travel-friendly. By solving the 'charger fatigue' of old-school batteries and doubling down on capacity and compatibility, it’s set to become the new gold standard for anyone shopping for lithium-ion power tool batteries.
Buy it Now
1. Teardown of Walmart Onn. 72W Multi-Port GaN Wall Charger (WIAWHT36008513)
2. DJI Launches 2 kWh Power Expansion Battery 2000: Enhanced Performance for Outdoor Power Solutions
3. Stay Powered Anywhere: IQ PowerPack 1500 Delivers 1,500 Wh of Reliable Energy with Rapid Charging and Versatile Outputs
5V High-Voltage LNMO | The Game Changer for Magnetic Power Banks
June 15, 2026
October 23, 2019
Teardown of  JOYROOM 5.3 FM/AUX Bluetooth Car Adapter (JR-CL18)
August 30, 2022
76 Modules Achieve Qi2 Wireless Charging Certification, with NuVolta, UGREEN, and Reflying Leading the Way
November 16, 2024
