Home › News › What's New › Aohi Launches “Adonis” USB4 2.0 Full‑Function Cable with 240 W Charging and 120 Gbps Transfer Speeds
Rebecca
June 26, 2025
Aohi has officially launched its latest high-performance cable, the “Adonis” USB4 2.0 full-function data cable, offering ultra-fast data transmission and high-power charging. Designed for professional and advanced users, the cable supports unidirectional data transfer speeds of up to 120Gbps and bidirectional speeds up to 80Gbps, enabling smooth operation in 8K video playback, AI data processing, and high-resolution file transfer.
Aohi Launches “Adonis” USB4 2.0 Full‑Function Cable with 240 W Charging and 120 Gbps Transfer Speeds-Chargerlab
The cable is compatible with dual 8K or triple 4K display outputs through DisplayPort 2.1, supporting complex display setups and creative workflows. It works with a wide range of devices including MacBook Pro (M4 Pro/Max), Mac Mini (M4 Pro), high-speed SSDs, docking stations, and various Thunderbolt or USB-C enabled equipment. In terms of charging capabilities, the Adonis supports Power Delivery (PD) 3.1 with up to 240W of output. This allows users to charge a MacBook Pro to 50% in just 30 minutes, significantly improving work efficiency by reducing charging times. Aohi highlights the cable’s high power and bandwidth compatibility as key features for tech professionals.
The cable structure includes an intelligent E-Marker chip, high-density 16-core coaxial construction, aluminum alloy shell for heat dissipation, and a flexible outer skin designed for daily durability and smooth handling. It has passed rigorous reliability tests and is rated for long-term use in high-intensity scenarios.
Available at a standard length of 1 meter (3.3 feet), the cable is priced at $39.99 USD with an 18-month warranty. Aohi offers international shipping with customs and duties included, positioning the Adonis cable as a reliable choice for users needing top-tier performance and compatibility with the latest USB4 and Thunderbolt 5 standards.
Buy Now
1. Review of AOHi Starship 40000mAh 140W Power Bank
2. Only $129.00 for a Limited Time: AOHI The Future Starship 240W 27,600mAh LED Display Power Bank
3. AOHi STARSHIP PD3.1: The Ultimate Power Bank with 40000mAh Capacity
120Gbps AOHi cable
Teardown of Lenovo Legion 245W GaN Adapter (LA245)
Teardown of Belkin 240W Dual USB-C Braided Cable
Mophie Adds USB-C Ports to Refreshed Powerstation Batteries
May 30, 2019
Ultra-thin Design | Baseus Blade Series 100W Power Bank Is Now on Amazon
October 26, 2022
Defense™ by X-Doria Launches Fast Charging Dual Qi Charger made with Luxury Leather and Metal
October 7, 2019
MOMAX Airbox Go Power Capsule: A Convenient Solution for Charging Anxiety and Cable Management
May 10, 2023
Rebecca
