Home › News › What's New › For iPhones丨mophie launched a speedport 30 1-port GaN wall charger (30W)
Jeffrey
August 29, 2022
ChargerLAB has found that, in addition to the iPhone 13 mini, which has the smallest battery, all the rest of the iPhone 13 series is more than 20W, especially the iPhone 13 Pro Max, with the largest battery capacity. That is to say, the 20W charger is not quite enough, so a 30W charger is necessary.
For iPhones丨mophie launched a speedport 30 1-port GaN wall charger (30W)-Chargerlab
As a strategic partner of Apple for many years, mophie has launched a portable 30W GaN wall charger for iPhone, which has passed Apple's certification and is now available in the Apple store.
It adopts a white and frosted fire-resistant shell, with compact size.
The glossy charger printed with the "mophie" logo and "30W, has a single USB-C port.
Its size is about 40.67 X 30.94 X 30.92 mm (1.60 X 1.21 X 1.21 inches), with the volume of 38.91cm³ (2.37 in³) and power density of about 0.77W/cm³.
The weight is about 48.8g (1.72oz), 56% smaller and 51% lighter than Apple 30W charger.
The ChargerLAB POWER-Z KM002C finds that it only supports PD3.0. And it also supports five fixed PDOs of 5V3A / 9V3A / 12V2.5A / 15V2A / 20V1.5A and two PPS of 3.3-11V3A / 3.3-16V2A.
When charging the iPhone 13 Pro Max, it triggers a handshake of 9V PDO with a power of 9.03V 2.92A 26.38W, reaching maximum output power of the phone.
When charging the iPad Air 5, it triggers a handshake of 15V PDO with a power of 14.98V 1.89A 28.45W, reaching maximum output power of the charger.
When charging the MacBook Pro 16, it triggers a handshake of 20V PDO with a power of 20.04V 1.43A 28.77W, reaching maximum output power of the charger.
The mophie speedport 30W GaN wall charger supports up to 30W of fast charging power to the devices. GaN technology increases charging efficiency and speed, so you get a lot of power in a compact cube that fits easily in your bag or pocket.
It features foldable prongs and a USB-C PD fast-charging port. It also comes with a 2m USB-C to USB-C cable.
1. Same but Different | Teardown of Apple 35W Dual USB-C Traditional Power Adapter
2. Completely Different | Teardown of Apple 35W Dual USB-C Compact Power Adapter
3. Teardown of Apple 12W USB-A Charger (A2167)
30W Apple Fast charging GaN Mophie
Charging Compatibility Test of REDMAGIC 7S
Up to 2400W丨 Baseus Launched 600W Portable Power Station with Digital Display (Parallel Operation)
Eggtronic Releases Sirius, the World's Smallest Foldable 65W Charger with GaN Tech
October 13, 2019
Flujo Signature Pro USB-C Hub with SSD Enclosure Launches on Kickstarter
October 15, 2019
Up to 1.89 W/cm³ | Bogrun Intelligence 65W Dual-port Card-like GaN Charger
September 20, 2022
February 12, 2026
Jeffrey
