Home › News › CEENR Introduces Cross-Brand Power Tool Battery Pack
CEENR Introduces Cross-Brand Power Tool Battery Pack-Chargerlab
Overseas brand CEENR has rolled out the PDnation Pro 8.0Ah universal tool battery, a groundbreaking product that breaks through traditional eco-system barriers. Packing a 144Wh (8.0Ah) high-capacity 21700 high-rate cell configuration, the battery pack innovatively supports 100W USB-C PD3.0 bidirectional fast charging and seamlessly connects to major power tool platforms using proprietary brand adapters. It brilliantly combines heavy-duty tool power delivery, high-wattage consumer fast charging, and cross-brand energy sharing, delivering a fresh portable power experience for garage, job site, and field technicians.
The core strength of the CEENR PDnation Pro rests on its superior electrical metrics and broad compatibility. Supporting 100W two-way power flow, it refills itself in roughly 90 minutes via standard PD bricks while doubling as a mobile power bank for laptops and phones, backed by comprehensive thermal and short-circuit protections.
Utilizing a modular "battery plus adapter" scheme, swapping the baseplate unlocks compatibility with over 1,600 tool models spanning 10 leading brands like DeWalt, Makita, Milwaukee, and Bosch. This cross-brand design eliminates the clutter of carrying redundant proprietary chargers and single-brand packs.
The CEENR PDnation Pro 8.0Ah thoroughly eliminates the frustrating brand silos plaguing conventional power tool batteries. Armed with 144Wh capacity, 100W two-way fast charging, and multi-platform adapter support, it dramatically raises the utility and reuse value of tool power. It transforms standard power packs into versatile assets for mobile fieldwork and emergency tech charging, setting a prime example for modular cross-sector energy storage. As USB-C PD integration scales deeper into heavy-duty segments, universally interconnecting, high-output cross-brand energy accessories are primed to lead the professional field.
June 19, 2026
May 19, 2026
May 25, 2026
Navitas Launches SiCPAK Power Module with Excellent High-Temperature Performance and High Stability
June 11, 2025
