Home › News › OPPO Launches Multiple Magnetic Accessories
The new OPPO Find X8 series, alongside other mobile intelligent ecosystem products, was unveiled at the OPPO product launch event on April 10. At the event, OPPO will introduce the OPPO Find X8s, OPPO Find X8s+, OPPO Find X8 Ultra smartphones, the OPPO Pad 4 Pro tablet, OPPO Watch X2 Mini, OPPO Enco Free4 earbuds, and other products.
OPPO Launches Multiple Magnetic Accessories-Chargerlab
In addition, this OPPO launch event will further enhance the OPPO Mag magnetic ecosystem by introducing more magnetic accessories, including the OPPO Magnetic Protective Case, OPPO Air Magnetic Power Bank, OPPO 27W Magnetic Cooler, and OPPO Magnetic Self-winding Cable.
OPPO Launches 4 OPPO Mag Ecosystem Accessories for the New Find X8 Series
The OPPO Magnetic Protective Case is specifically designed for the new Find X8 series. Although the phones themselves support wireless charging, they will not include a magnetic charging coil for a thinner build. By using the Magnetic Protective Case, users can enable magnetic wireless charging and gain access to additional OPPO Mag accessories.
From the promotional images, the case will be available in multiple colors, including dark blue, light blue, green, yellow, pink, and gray. Based on previous iterations of magnetic phone cases, this new version will not only support OPPO’s Mag ecosystem but will also be compatible with Apple’s MagSafe ecosystem, allowing for the use of more third-party accessories and offering a wider range of accessory choices.
The OPPO 27W Magnetic Cooler is already available for pre-order on OPPO’s official website and major e-commerce platforms, though more details have yet to be revealed.
The cooler is designed to greatly enhance the performance and temperature control of the OPPO Find X8 series and other devices under high load conditions.
The magnetic power bank Air features a Cloud Blue color and is equipped with a 5000mAh battery.
The power bank will use new materials, with a magnetic surface covered in skin-friendly silicone, and it supports magnetic charging for phones. Besides being compatible with OPPO’s own Mag ecosystem, it is also compatible with Apple’s MagSafe ecosystem, allowing easy charging with a simple snap.
In addition to the above magnetic accessories, OPPO also launched the OPPO Magnetic Self-winding Cable, which features a double Type-C interface. It has a self-coiling magnetic design and supports OPPO’s SUPERVOOC fast charging.
Other Accessories
In addition to the magnetic accessories mentioned above, the event will also showcase the OPPO 100W Super Flash Charger in a compact GaN design.
Additionally, there is a new cable product that also supports OPPO’s SUPERVOOC fast charging.
From the promotional images, this data cable can serve as both a charger and a fashion accessory. Paired with the colorful magnetic phone cases, it can be worn as a strap, combining both aesthetic appeal and functionality.
The launch of the OPPO Find X8 series and Mag magnetic ecosystem accessories further enhances the brand’s position within the mobile device ecosystem. From the Mag protective case that supports multiple platforms to the performance-enhancing cooler, from the lightweight power bank to the fashionable and functional data cable, each accessory shows attention to detail and an understanding of user needs. The compatibility with Apple’s MagSafe ecosystem also gives consumers greater flexibility and demonstrates OPPO’s innovative approach to open collaboration.
OPPO
Teardown of ANKER 253W GaN Power Adapter (A91B2-Adapter)
Unboxing of UGREEN Nexode 500W GaN Charger
Only $129.00 for a Limited Time: AOHI The Future Starship 240W 27,600mAh LED Display Power Bank
April 28, 2025
Breaking News: iPhone 15's USB-C Port and the Revelation of a Mystery Chip!
August 15, 2023
15
Lenovo and ROG Laptops are the First to Support OCuLink, Which is Faster Than Thunderbolt 4
September 29, 2024
Teardown of Lenovo XiaoXin / Ideapad CC 100W GaN Charger
June 20, 2021
