Accessory maker Baseus unveiled a 2C1A (two USB-C ports and one USB-A port) multiport GaN charger – a world’s first, at a special event in Shenzhen, China, on August 18.
The 65W PD charger is base on GaNFast solution from Navitas which enables high wattage inside an ultra compact form factor. It also makes the first debut of GaNFast on a multiport charger (the RAVPower 45W Ultrathin and AUKEY 27W PA-Y19 are single port chargers based on GaNFast). GaN, or Gallium Nitride, which is a new type of semiconductor material that offers higher efficiency, higher thermal conductivity, higher temperature resistance, and other advantages than traditional silicon. When it comes to charging, GaN can greatly reduce the size and boost the efficiency of a charger.
The charger has foldable prongs that we all love.
An LED indicator on the side.
Specifications of the Baseus 2C1A multiport 65W PD GaN charger:
USB-C1 Output: 3.3V-11V/3A, 5V/3A, 9V/3A, 12V/3A, 15V/3A, 20V/3.25A Max
USB-C2 Output: 3.3V-11V/2.7A, 5V/3A, 9V/3A, 12V/2.5A, 15V/2A, 20V/1.5A Max
USB-C2+USB-A Output: 5V/3A
It will be available in mainland China starting in early September. Stay tuned!
22 COMMENTS
  1. Seems dishonest to market something as “PPS FULL QUICK CHARGE PROTOCOL” when it only does 3.3V-11V / 3A.
    There are about 10 MILLION Samsung Note 10+ units being sold in the next year, ALL of them are 45W USB PD3.0 PPS compliant, yet only shipping with a 25W charger. There are millions of people looking for a 45W PPS compliant charger hoping to get the full 3.3-11V / 4.05A protocol for their note.
    This charger will only support 33W in PPS mode.
    Note 10+ users beware, there is still no 45W PPS compliant GaN charger for your Note 10+ as of 9/3/2019.
    I can’t even think how many of these units will be returned or purchased in error.
    • I think by “PPS FULL QUICK CHARGE PROTOCOL” they meant “Full quick charge protocol support including PPS”. The event was aimed at the Chinese market, the wording in English could be hit-or-miss sometimes.
      But I share the same view with you on PPS. Let’s hope more high-wattage-PPS-capable chargers coming to the market.
  2. […] Gallium nitride (GaN) chargers have reached the market at a rapid pace since the first batch was released earlier this year: we started with smaller 30W and 45W, before turning them into small 60W bricks and double USB-C chargers that are smaller than traditional bricks with one plug. And now accessory company Baseus is continuing that trend with a GaN-based charger with two USB-C ports and a USB-A port, but still small enough to fit in the palm of your hand, through Charger Lab. […]
  3. […] Nitreto de gálio (GaN) carregadores estão chegando ao mercado em um ritmo acelerado desde que o primeiro lote foi lançado no início deste ano: começamos com 30W e 45W, antes de aumentar para minúsculos 60W tijolos e carregadores duplos USB-C que são menores que os tijolos tradicionais de plug único. E agora, a empresa de acessórios Baseus está levando essa tendência ainda mais longe, com um carregador baseado em GaN que possui duas portas USB-C e uma porta USB-A, mas ainda é pequena o suficiente para caber na palma da sua mão, através da Charger Lab. […]
  4. […] Gallium nitride (GaN) chargers have been hitting the market at a rapid pace since the first batch came out earlier this year: we started with smaller 30W and 45W, before bumping that up to tiny 60W bricks, and double USB-C chargers that are smaller than traditional single plug bricks. And now, accessory company Baseus is taking that trend even further, with a GaN-based charger that features two USB-C ports and a USB-A port, but still is small enough to fit in the palm of your hand, via Charger Lab. […]
  5. […] Gallium nitride (GaN) chargers have been hitting the market at a rapid pace since the first batch came out earlier this year: we started with smaller 30W and 45W, before bumping that up to tiny 60W bricks, and double USB-C chargers that are smaller than traditional single plug bricks. And now, accessory company Baseus is taking that trend even further, with a GaN-based charger that features two USB-C ports and a USB-A port, but still is small enough to fit in the palm of your hand, via Charger Lab. […]
  6. […] Gallium nitride (GaN) chargers have been hitting the market at a rapid pace since the first batch came out earlier this year: we started with smaller 30W and 45W, before bumping that up to tiny 60W bricks, and double USB-C chargers that are smaller than traditional single plug bricks. And now, accessory company Baseus is taking that trend even further, with a GaN-based charger that features two USB-C ports and a USB-A port, but still is small enough to fit in the palm of your hand, via Charger Lab. […]
  7. […] Gallium nitride (GaN) chargers have been hitting the market at a rapid pace since the first batch came out earlier this year: we started with smaller 30W and 45W, before bumping that up to tiny 60W bricks, and double USB-C chargers that are smaller than traditional single plug bricks. And now, accessory company Baseus is taking that trend even further, with a GaN-based charger that features two USB-C ports and a USB-A port, but still is small enough to fit in the palm of your hand, via Charger Lab. […]
  8. […] Gallium nitride (GaN) chargers were hitting the market at a like a flash slump since the first batch came out earlier this year: we began with smaller 30W and 45W, sooner than bumping that as a lot as little 60W bricks, and double USB-C chargers which are smaller than former single slump bricks. And now, accent firm Baseus is taking that trend even further, with a GaN-based mostly entirely charger that functions two USB-C ports and a USB-A port, nonetheless light is miniature ample to slot within the palm of your hand, through Charger Lab. […]
  9. […] Gallium nitride (GaN) chargers have been hitting the market at a rapid pace since the first batch came out earlier this year: we started with smaller 30W and 45W, before bumping that up to tiny 60W bricks, and double USB-C chargers that are smaller than traditional single plug bricks. And now, accessory company Baseus is taking that trend even further, with a GaN-based charger that features two USB-C ports and a USB-A port, but still is small enough to fit in the palm of your hand, via Charger Lab. […]
  10. […] Gallium nitride (GaN)chargers have been hitting the market at a rapid pace since the first batch came out earlier this year: we started with smaller30Wand45W, before bumping that up to tiny60Wbricks, anddouble USB-C chargersthat are smaller than traditional single plug bricks. And now, accessory company Baseus is taking that trend even further, with a GaN-based charger that features two USB-C portsanda USB-A port, but still is small enough to fit in the palm of your hand,viaCharger Lab. […]
  11. […] Gallium nitride (GaN) chargers have been hitting the market at a rapid pace since the first batch came out earlier this year: we started with smaller 30W and 45W, before bumping that up to tiny 60W bricks, and double USB-C chargers that are smaller than traditional single plug bricks. And now, accessory company Baseus is taking that trend even further, with a GaN-based charger that features two USB-C ports and a USB-A port, but still is small enough to fit in the palm of your hand, via Charger Lab. […]
  12. […] Gallium nitride (GaN) chargers have been hitting the market at a rapid pace since the first batch came out earlier this year: we started with smaller 30W and 45W, before bumping that up to tiny 60W bricks, and double USB-C chargers that are smaller than traditional single plug bricks. And now, accessory company Baseus is taking that trend even further, with a GaN-based charger that features two USB-C ports and a USB-A port, but still is small enough to fit in the palm of your hand, via Charger Lab. […]
  13. […] Gallium nitride (GaN) chargers have been hitting the market at a rapid pace since the first batch came out earlier this year: we started with smaller 30W and 45W, before bumping that up to tiny 60W bricks, and double USB-C chargers that are smaller than traditional single plug bricks. And now, accessory company Baseus is taking that trend even further, with a GaN-based charger that features two USB-C ports and a USB-A port, but still is small enough to fit in the palm of your hand, via Charger Lab. […]
  14. […] Gallium nitride (GaN) chargers have been hitting the market at a rapid pace since the first batch came out earlier this year: we started with smaller 30W and 45W, before bumping that up to tiny 60W bricks, and double USB-C chargers that are smaller than traditional single plug bricks. And now, accessory company Baseus is taking that trend even further, with a GaN-based charger that features two USB-C ports and a USB-A port, but still is small enough to fit in the palm of your hand, via Charger Lab. […]
  15. […] Gallium nitride (GaN) chargers have been hitting the market at a rapid pace since the first batch came out earlier this year: we started with smaller 30W and 45W, before bumping that up to tiny 60W bricks, and double USB-C chargers that are smaller than traditional single plug bricks. And now, accessory company Baseus is taking that trend even further, with a GaN-based charger that features two USB-C ports and a USB-A port, but still is small enough to fit in the palm of your hand, via Charger Lab. […]
Leave a Reply to O novo carregador GaN da Baseus coloca duas portas USB-C e uma porta USB-A juntas em um pacote do tamanho de uma palma - Replicario Cancel reply
Please enter your comment!
Please enter your name here
