Our exclusive hands-on of the world’s first 2C1A multiport GaN charger – the Baseus 65W 2C1A multiport GaN charger, which was unveiled at a special event in Shenzhen, China, on August 18. The charger has foldable prongs and an LED indicator on the side. It will be available in mainland China starting in early September.
Our exclusive hands-on video:
The 65W 2C1A charger is based on GaNFast solution from Navitas which enables high wattage inside an ultra compact form factor. It also makes the first debut of GaNFast on a multiport charger (the RAVPower 45W Ultrathin and AUKEY 27W PA-Y19 are single port chargers based on GaNFast). GaN, or Gallium Nitride, which is a new type of semiconductor material that offers higher efficiency, higher thermal conductivity, higher temperature resistance, and other advantages than traditional silicon. When it comes to charging, GaN can greatly reduce the size and boost the efficiency of a charger.
Specifications:
USB-C1 Output: 3.3V-11V/3A, 5V/3A, 9V/3A, 12V/3A, 15V/3A, 20V/3.25A Max
USB-C2 Output: 3.3V-11V/2.7A, 5V/3A, 9V/3A, 12V/2.5A, 15V/2A, 20V/1.5A Max
USB-C2+USB-A Output: 5V/3A
Were you able to test the charger on a MacBook or any laptop that uses the USB-C for power?
Will do later.
[…] Photo: Charger Lab […]
[…] By everythingtoday – September 12, 2019 0 0 views Share on Facebook Tweet on Twitter var td_screen_width = window.innerWidth; if ( td_screen_width >= 1140 ) { /* large monitors */ document.write(''); (adsbygoogle = window.adsbygoogle || []).push({}); } if ( td_screen_width >= 1019 && td_screen_width < 1140 ) { /* landscape tablets */ document.write(''); (adsbygoogle = window.adsbygoogle || []).push({}); } if ( td_screen_width >= 768 && td_screen_width < 1019 ) { /* portrait tablets */ document.write(''); (adsbygoogle = window.adsbygoogle || []).push({}); } if ( td_screen_width < 768 ) { /* Phones */ document.write(''); (adsbygoogle = window.adsbygoogle || []).push({}); } Photo: Charger Lab […]
Is there a chance that North America buyers can get such ones? I tried searching and found only a UK importing website is selling it and of course that is the UK plug. Would be so happy to buy it in North America.
They are not ready for sale in in North America yet. But I think they will make them available in the US, since they launched a few products for the US.
Įs it possible to use it with 19v 3.42a asus laptop?
It is possible, but you need a barrel to USB-C converter (or cable).
